Dsp with aftermarket radio
  • 3
It won't hurt anything. Everyone I know that has added one said once it was setup properly the sound was improved. Depends on what you want to spend. They can go from 160 bucks up to 1k. Even though I have a DEH-80PRS I am going to add probably the Helix I have sitting here later on this year.
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
609
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
531
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
Mr.Jackson
Mr.Jackson
Stone Mountain Ga
Louisiana_CRX
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
