Speakers making noise when adjusting amp
Bass so loud it HZ
So I just recently upgrade to 2 RS plat 18s a few weeks ago .yesterday I got my new surge 10k and it seemed to work fine. When I went to adjust it and fine tune it today my speakers would make an awful sound when adjusting . I thought maybe one of my speakers was blown or a speaker wire had came loose. I pulled them out and the coils still look good and it alltested out wires were all hooked up correct .has anyone ever had this problem ? Thinking my amp could be faulty
Could be dirty potentiometers. Try doing full sweeps with the system off, then try it out.
This!! Ive had some of my older amplifiers do same thing from sitting up a while. Just hitting them with a swifter on the outside does very little for and dust accumulation on the inside. If your amplifier is under warranty... send it back. If out of warranty.. You can crack it open and do some cleaning. Dielectric spray works well.
I literally just bought it and installed it the day before I wrote this post .but I did what Ole boy said and I haven't had a problem since
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
133
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
251
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
129
38
Bass so loud it HZ
Bass so loud it HZ
IN, United States
Bass so loud it HZ
    May 20, 2024
    May 20, 2024
