Speakers making noise when adjusting amp
  • 3
Bass so loud it HZ
CarAudio.com Regular
So I just recently upgrade to 2 RS plat 18s a few weeks ago .yesterday I got my new surge 10k and it seemed to work fine. When I went to adjust it and fine tune it today my speakers would make an awful sound when adjusting . I thought maybe one of my speakers was blown or a speaker wire had came loose. I pulled them out and the coils still look good and it alltested out wires were all hooked up correct .has anyone ever had this problem ? Thinking my amp could be faulty
Could be dirty potentiometers. Try doing full sweeps with the system off, then try it out.
This!! Ive had some of my older amplifiers do same thing from sitting up a while. Just hitting them with a swifter on the outside does very little for and dust accumulation on the inside. If your amplifier is under warranty... send it back. If out of warranty.. You can crack it open and do some cleaning. Dielectric spray works well.
I literally just bought it and installed it the day before I wrote this post .but I did what Ole boy said and I haven't had a problem since
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
5
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
128
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
434
It may be that they act like this because they are underpowered and the push to play them louder is causing the amp to clip the signal, which will...
Bass so loud it HZ
Bass so loud it HZ
IN, United States
Bass so loud it HZ
Latest topics
