Mounting subs in existing metal dead space
  • 6
rogermija
In my RV there is an unused cavity just below the kitchen floor but exposed after removing a sheet metal plate in the cab area. The cavity is approximately 8"h x 5"d x 30" w. There is room for one or two 6.5" woofers. Being structural metal, will the cavity work as a sound box? If needed, there is room for a tube port through the floor. Will this cavity work and, if so, what parameters should I consider? Thank you.
Metal resonates too much for a subwoofer enclosure. I'd fiberglass that space. You have ~.75cuft to work with, which is a decent amount of space for two 8s sealed or single 8 ported.
Thank you for the response. Glassing would be a challenge. Would self adhesive sound absorbing rubber or some thing similar work?
Sound deadeners won't cut the mustard IMHO. Why can't it be glassed?
If you're just trying to throw something in and keep it as easy and simple as possible, then I'd sound deaden the area, go sealed and use a high quality acoustic damper like Acousta-Stuf. You'll probably end up with ringing. You can dampen the front side of the cone to help control the ringing, but that will cost you efficiency and potentially output depending on the sub.
Thanks again. The metal is part of the chassis frame except for a portion of the sheet metal which has three stiffeners along the 30" portion. The front of the space is currently enclosed with sheet metal accessible from the rv cab area. I plan on removing an 8" x 15" section. Glassing may be a challenge through that small opening especially in the far corners. I'll check out Acousta-Stuf.
A photo of the area would be helpful.
I have not cut the access hole yet. But I will get a snap for reference. In the meantime, how does Acousta-stu compare to acoustic foam for this application? Thank you.
Acousta stuff is more to give the space the illusion of more airspace but also damps sound. Acoustic foam just damps the sound. Acoustic foam could be a good option too.
fill the cracks with Great Stuff foam. trim the excess off with a razor blade after it dries. Use spray on bedliner to thoroughly cover the inside. Multiple coats. Use a 3/4 inch or 1 inch thick wooden baffle for the subs and make sure it’s screwed down sealed well.
Yeah, maybe stick some deadener on the bare metal before you spray the bedliner.
How much power are we talking?
Thanks. Area for sub mounting is approximately 15" wide and 8" high. There is a 1" vertical stiffener brace half way across.
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
259
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
5K
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
rogermija
rogermija
Raleigh, NC
huberoy123
    May 16, 2024
    May 16, 2024
