Boost voltage
  • 2
I have the same alt just get a 50k adjustable trim pot and wire it in with the voltage since wire on the alternator so that you can dial it in. Or if your vehicle has a battery temperature sensor like my Dakota had which tells the PCM if the battery is cold or hot so that the alternator doesn't overcharge the battery so what I did because my sensor needed to be replaced I instead just cut the sensor off and wired the trim pot to that and I was able to adjust my voltage from 13.2v to 15v 🤘
I tried to find a sense wire on mine and couldn't. Maybe I'm missing something .I'll see if it has a temp sensor .I'm trying to get up to around 16vs tho
Odds are that the factory subwoofer isn't going to be able to handle any more power than whatever they put to it at the factory and you would...
It's hard to find the old fashioned stuff anymore actually. Glad the new unit has the features you like. In future I'd always suggest calling up...
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
591
Bass so loud it HZ
Bass so loud it HZ
IN, United States
Bass so loud it HZ
