Wiring 2 channel amp with 4 speakers
  • 1
Lug Nut
CarAudio.com Newbie
Wiring question....using four 4 ohm speakers and one 2 channel amp capable of 2.ohm load...
Using 2 ohm stable 2 channel 4 ohm amp to power four 4 ohm speakers (motorcycle application) Two 6.5 speakers in fairing and two 5.25 in speakers in tourpack and running rca-to-aux cable directly to my phone (no head unit or blue tooth or anything else. Don't need to balance or fade...just plug into phone and stream or playlist and use phone volume button for stereo volume. Did this with same amp and a pair of 6x9 and worked well (obviously just 2 channel 4 ohm load).
Sundown sdx 90.2 amp (4 ohm 2 channel amp that is 2 ohm stable)
Memphis Sound 6.5in (6 3/4 actually) 4 ohm 2 way speaker in fairing and some other marine type 5.25in 4 ohm speaker in tourpack.
what would be the best method to wire this system....series or parallel and any examples/diagrams?
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
350
Lug Nut
CarAudio.com Newbie
Lug Nut
Avilla, IN
Lug Nut
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
