Amp?
  • 2
Battery expert 2023
I am going to buy 1 DC Audio 15 level 3 dual 2 ohm sub. My question is are the DC Audio amps as good as what the subs seem to be? It was recommended that the CS 1100/1 amp would work well. It is only 350 bucks so the price is not a problem just any general info on DC Audio amps would be helpful.
Get the crescendo s1v2.right at 300 out the door,smaller foot print,does 1650 rms at 13.8..i have that and is only 3 months old before i bought its big brother the s1 plus.these are damn good amps.clean and loud and sound great.korean board with working voltage down to something like 9.
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
Getting a good voltage reading does not mean good power transfer. You could read 13.8v out of a 24 AWG wire. Recheck your amplifier's ground and...
245
456
Battery expert 2023
Battery expert 2023
Antarctica
Bass Addict
Decebal
    Jun 10, 2024
