Box leaking air??
this same thing happened to me when i was installing my 5.25's. I went to mount the new speaker and i over tightened and snapped off one of the screw heads leaving me with only 3 screws holding the speaker in place. I powered it and that one speaker sounded absolutly awful with that rattling noise so i drilled a new hole thru the mount and got new screws and it works perfect. good luck hope this helps
IDK if the box is savable but I can try how would I go about that double baffle Idea How would I cut the hold for the sub I dont have router?
Its definatly coming from the cone of the sub, But its not the sub because I tested it with another sub and it did the exact same thing, Its a very Rattley type of sound from the cone area when the bass hits. cant hear it in the car but I know its not right and its ****in annoying. Also I dont want to damage the sub. I want to just have a box built to specs Does anyone know someone on here that can build a box in the L.A. area??
E6000
Only 13 years late with that reply....
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
84
427
778
618
my_stealth21
my_stealth21
Tulsa,OK
    May 18, 2024
    May 16, 2024
