JVC KW-M780BT help
  • 2
Probably because Apple Maps is designed by Apple and seamlessly integrated into the propietary software.
Yeah, but Apple Maps has nothing to do with FM radio stations, and neither does Google Maps, so why can I only listen to FM stations while using Apple Maps, and not Google Maps?
Years back I contacted Pioneer to ask why their radios linked better with Iphones than with Android phones. They said because Apple coded the software and shared it with them. So it would be no surprise if Apple approached other manufacturers with the same offer. Hence my assumption why Apple Maps would work seamlessly on your Iphone with the radio. Whereas Google Maps is a 3rd party add-on.
All just an assumption.
It all works fine, I had to change the Bluetooth connection type on my iPhone from being blank, to car stereo
Google do it translate what ever i do
376
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
JohnPD
JohnPD
Ravenna, Ohio
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
