JVC KW-M780BT iPhone using Google Maps, no FM radio music, only what's on my phone.
  • 3
JohnPD
CarAudio.com Regular
I like Google Maps better than Apple Maps. Google Maps works just fine via USB, but for some reason I cannot listen to any FM radio stations while using Google Maps, but I can listen to whatever music is on my iPhone. Using Apple Maps I can listen to whatever music source I choose with no problems. Any ideas how to fix this?
Years back I contacted Pioneer to ask why their radios linked better with Iphones than with Android phones. They said because Apple coded the...
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
JohnPD
JohnPD
Ravenna, Ohio
JohnPD
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
