need help with tuning/speakers not working
i just picked up a half rack with a pair of mids and tweeters, as well as a Taramps 800x4.. i dropped it off at the audio sho and they rewired it for me but now my front door speakers aren't working... i tried messing with the crossover but not sure if that sthe problem
Did the shop rewire the audio system on the vehicle, or just the rack?
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at...
17
Thank you it sounds way better then it was And I fixed why it was cutting off it was because of bad power because the full range amp was losing...
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
139
721
maninikine
maninikine
Ewa Beach, Hawaii
Silicon oxide
    May 19, 2024
    May 19, 2024
