need help with tuning/speakers not working
  • 3
i just picked up a half rack with a pair of mids and tweeters, as well as a Taramps 800x4.. i dropped it off at the audio sho and they rewired it for me but now my front door speakers aren't working... i tried messing with the crossover but not sure if that sthe problem
Did the shop rewire the audio system on the vehicle, or just the rack?
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at...
17
Thank you it sounds way better then it was And I fixed why it was cutting off it was because of bad power because the full range amp was losing...
4
11
544
662
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
932
maninikine
CarAudio.com Newbie
maninikine
Ewa Beach, Hawaii
Silicon oxide
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
