Newb needing little help with LC-5.1300
  • 2
Can mids and tweets be run on same channel 1/2 and use 3/4 for rear door coaxial and 5/6 for two subs on Lc-5.1300
To run mids and tweets on the same channel, you will need a passive crossover to split the signal into two parts: one for the mids and one for the tweets. A passive crossover is a device that uses capacitors and inductors to filter out unwanted frequencies from each speaker. Without a passive crossover, you will risk damaging your tweets by sending them too much power or distorting your sound by sending them the wrong frequencies.
Thank you for the response. I know a lot of people bag on them here but I have 6.5 kicker cs series component with crossovers so would that work
They should work.
I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s in the upper door.
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
You may or may not like the sound of just dropping into the stock locations but loading into the glass is definitely going to cause some issues...
15
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
823
You got plenty of space 30"h x 40.5"w x 65"d even triple baffled, double walled with bracing. What vehicle is this going in may I ask?
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
jgray77
jgray77
north carolina
huberoy123
    May 18, 2024
    May 18, 2024
