Current Punch 60IX
Thanks for the quick response. Jim
It is drawing about 4 amps at idle. Doesn't seem to over heat though. Thought that was a bit much.
Class A/B, right? If I recall, these little 2x30 watt jems could best several hundred watts, mono. One of RF's endearing qualities on most of their equipment, you always knew you were getting more than you paid for.
Yeah i Yeah I know. I have my sub wired at 4ohm so I can get 300w rms from old amp. It’s 1000w max. And yes that’s the reason I got this pioneer...
40
4K
I like the MA Audio HK series ..ive ran and won with them at car audio comps
If you have not already done this, do a thorough job of sound deadening the doors before spending a lot of money new equipment. This is probably...
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
903
Jim Trucks
Jim Trucks
Florida
    May 11, 2024
RedRyder18
    May 11, 2024
