Scar rp 1200 amp settings
More information is needed. What is the rest of the system, what are they being blended with? Speakers, HU, other amplification?
SDR's, dual VC, single VC, ohms rating per coil?
And it's Skar...
I bought 2 scar sdr 12"s in pre fab box I have a scar RP 1200 amp . Where should my settings be set at ? Thanks for the feedback
80 Hz LPF, 30 Hz Subsonic, 12 dB Bass EQ (if it does not blend well with the front stage, set it to 6 dB). For the Gain, set it completely off, turn up radio to the loudest you would play it on a song you know well. Turn up bass knob halfway, turn Gain until bass sounds great with the front stage.
As you listen to the system you may want to make Gain adjustments. Do not hesitate to fiddle with it or the bass knob. You will eventually find the perfect spot for your music preference.
Thanks for the input
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
It should be fine as long as you're not looking to upgrade in the future.
  • Poll
Its not a huge upgrade and I'd argue you likely couldn't tell the difference.
  • Locked
I have one if you are still looking
Out of those two for the money.. Id go with the Kicker. they still make great amps
Chad Otto
Chad Otto
Ocean shores Washington
Chad Otto
    May 18, 2024
    May 18, 2024
