Kicker 1200.1 or SIA 1250?
  • 3
Which is the overall better amp for a SA v.2 D4 10' subwoofer? Which one would make the sub have better sound quality especially on the lows?
The kicker as long as it's not the base model probably will sound better but I doubt you could even tell th difference. The sia amp is a good amp all the same so I would go off of price and brand preference
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
595
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
bryanarriaga67
CarAudio.com Newbie
bryanarriaga67
Texas
audiobaun
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
