1966 Corvette Custom Autosound Radio Won't Preset
BJ1k
I bought this Custom Autosound Concours Series USA-230 radio a couple years ago ,installed it in my Corvette but never played with it to set things in . When I try to find local stations and nudge the station button to manually find a station so I can preset it the radio just starts seeking and I can't just manually click it to the stations that I want. It just continually seeks a station. The owners manual says to just manually turn the tune knob to right or left to find the right number that I am looking for but it just keeps seeking . What could be wrong ?
Are you ever able to tune in to a station, manually?
Does it say "manual" when you do a partial turn and hold of the dial?
It should do that and manually tune, then go back to automatic search the next time you turn the knob.
Have you tried using a different antenna? Kind of sounds like you are not getting any signal. When that happens, there isn't anything to lock onto and the scanner just keeps scanning along.
This morning I checked the connection on the end of the antenna wire and where someone had put a new end on it and it wasn't getting a good connection so I cut it off and reinstalled it and it started working . I also did what you said with a partial turn and that seems to help also. Thanks for all of the suggestions >
Awesome, love it when things work!
1. Sure, it would function but it would look a little half arsed. Ideally you would use a distro block and run separate wires to each amp or...
745
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
BJ1k
BJ1k
Pittsburgh , Pa.
DEW123
    May 7, 2024
DEW123
    May 7, 2024
