Single din radio problem
I love my SONY DSX M80 but I'm having a problem with it when I turn my car on and stero turns it plays for a few Secs then cuts out about twice then continues playing just fine.
2nd problem is when there is someone else in my car who is paired (not connected) just paired and I'm connected it counts in and out constantly
Not sure what would cause those issues. I would venture a guess and say it is the BT identifying nearby devices and giving notification or trying to automatically connect. Try erasing all BT devices except yours and see what happens.
Check each speaker for shorts. A pinched wire grounding out or a individual blown speaker can sometimes make the internal amp go into protection.
745
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
474
Charlotte
    May 16, 2024
    May 16, 2024
