😬😖NEED LIL GUIDANCE..'12 ARMADA PLATINUM🙏🤞
  • 1
JAY¿FKN¿VAL
CarAudio.com Newbie
10
NY
I Got 2012 nissan armada platinum W/Bose 11 speaker nav/dvd/stereo, wanna leave the H.U. stock
(DVD & NAV are frequently used, wanna leave as is) I'm looking to splice into signal wire from H.U. to stock bose amp that's above gas pedal & run aftermarket subs,
🤷‍♂️1 or 2 sets steel tweeters & amp. I've researched and saw that I'd need a harness to add aux feeds needed for new components. Saw repeatedly a plug & play T harness thats suggested, but can't seem to find exact one I'd need. I also picked up infinity kappa component speakers for upgrade to front & rear door stock bose speakers, the only impedance compatible upgraded speakers work with bose 2.5 - 3ohm stock H.U. wanna eventually remove or upgrade stock sub under driver seat...... Im hoping somebody may point me in right direction & kik me in ass towards somewhere I can find
T harness to add amp???????
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
170
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
126
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
470
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
362
JAY¿FKN¿VAL
CarAudio.com Newbie
JAY¿FKN¿VAL
NY
JAY¿FKN¿VAL
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
