0 or 1/0 Gauge OFC Wire...whats the cheapest option
  • 3
adjetta
I am in the maket for Some Affordable zero gague ofc Power wire.
after discovering that the wire I had believed to be 0 gauge OFC was actually some oversized 1/0 CCA junk...after it was already too late, I am at a bit of a loss.
I don't really care about the flexibility, I just need to carry 300 amps reliably and cheaply, what are some decent contenders, links would be amazing but names are fine, my adhd has made my price shopping a bit of a debacle, so I gave up on it lol
I really need enough to run a mid sized sedan, dual batteries, big three w/ additional alt casing ground, and multiple grounds for my auxilary battery
thinking 25' would take care of it but idk for sure
0 and 1/0 are the same thing, bud, just by different names. Also, not all CCA is created equal nor what I would consider "junk." Do you have a spending limit?
well I would like to spend under 100 bucks, but I understand that you pay for quality and would spend more if I absolutely had to
oh here is an after though, in my experience every cca wire I have ever used has corroded, I need something that will hold up and not leave me stranded with a motor that wont crank due to a ground that is blacker than a coal miner's soul
The cause of corrosion is poor termination at the ends. If you use a good quality shrink wrap and copper closed-end lugs, you're far less likely to see the effects of corrosion on that wire. Even OFC is prone to the same weathering effects. If you use a combination of heat-shrink sleeves, copper lugs, and torch/solder, you shouldn't have the same issue.
As for finding OFC in your target range (as I think you really don't want to be hearing about CCA any more), look at weldingsupply.com and their stock of 0ga or 2/0 wire. Should be able to find a 30ft run within your budget.
  • Locked
COMPLETED 4 gauge OFC
These guys got it all. https://www.acdcwireandsupply.com/MTW_4_AWG_RED_MACHINE_TOOL_PRIMARY_WIRE_p/mtw-4awg-red.htm
That nvx wire is good stuff...I bought a 1/0 ofc kit...it's easy to work with
19
3K
Nope, just purchased and received it for my brothers "74" Ford Currier truck resto build. Small 4 cahnnel taramps and a set of nice 6.5" Pioneer Z...
12
adjetta
adjetta
Louisville
1.21 jiggawatts
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
