03 Silverado install issues
  • 3
knotdrummer88
Hi there,
I'm putting an alpine HU in my dads 03 Silverado w/o Bose radio and came into a few hiccups. First of all, the truck side of the harness does not have a remote turn on wire, do I have to run one myself? Secondly, I did put it in the dash and plugged it in before I realized I didn't have a remote wire and when I did that tge truck would start but only run for about a second. Any thoughts?
Thanks guys
Do you have the security bypass module? I'll assume no. Also the truck side won't have a remote on you run that wire to an amp.
This truck doesn't have an amp in it, and I believe I have the security bypass system from pac audio
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
581
Very true, however I also am having trouble finding a speaker that would appear to fit the bill, several have tweeters and a woofer, but not a sub...
52
7K
I have a nissan and i put mine on a switch that has my aftermarket reverse lights.worse case scenerio,u can do that.i just have to flip the toggle...
9
This is not subjective. Matching the resistance of a given speaker to the amplifier in use is part and parcel of the function of the system. If...
18
knotdrummer88
knotdrummer88
Toledo, OH
serjr711.
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
