07 Mustang Shaker500 head unit swap questions
  • 1
Lhnetman
CarAudio.com Newbie
I’m replacing the factory Shaker500 head unit with a Kenwwod Excelon one. The factory setup has 8” sub in each door. The Metra harness that is needed has a rca that plugs into the aftermarket “sub out”. My question is how do I add a sub in the rear? Do I just “split” the output(y-adatpors) so both amp receives the signal?
Thanks
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Might not even be an issue if you don't have any really big panels on it. Otherwise dowels or threaded rod across your wide panels would be the...
18
I ordered the car with the upgraded B&O audio system....turn's out Ford bought the name but they didn't buy the quality. The system ****** to me...
Contact ANS he has a used Focal 8 Channel DSP that went for 1,300 bucks and is selling used I think shipped for 450. And from what I have seen and...
13
6
117
Lhnetman
CarAudio.com Newbie
Lhnetman
Lhnetman
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
