08 Silverado, Diamond Audio, Lunar
subfrontier
Lunar Amplifiers
166
Louisiana
I made some changes to the system in my truck. I plan on upgrading the door speakers at a later date.
Alpine 9887
Lunar L450 on Boston Acoustics SX60's
Lunar L1500 on 2- Diamond Audio D6 12's
Doesn't leave much room to sit in the backseat. //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
I've got an '08 Silvey X-tra cab as well...box is under the seat...only 2 10" subs but I'm old and into SQ over rattling the fillings out of my rotting old teeth. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I mounted both amps in the center console...nice n' neat install...looks stock but sounds grrrrreat! I s'pose I should post some pics....someday.
They are really small boxes and can be stacked to one side or removed easily. I am considering to remove the small section of the rear seat and install my 12's in that area.
I had a Probox upfire with two DD 10's and I never did like the sound of it. The Diamond Audio D6 subs sound 100% better then the DD subs. The D6 subs are very accurate and get loud if needed.
I would like to see pics of your install
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
639
Very true, however I also am having trouble finding a speaker that would appear to fit the bill, several have tweeters and a woofer, but not a sub...
52
7K
I have a nissan and i put mine on a switch that has my aftermarket reverse lights.worse case scenerio,u can do that.i just have to flip the toggle...
This is not subjective. Matching the resistance of a given speaker to the amplifier in use is part and parcel of the function of the system. If...
18
subfrontier
Lunar Amplifiers
subfrontier
Louisiana
subfrontier
    May 31, 2024
    May 24, 2024
