1.4 ohm coils
  • 4
eutechnyx
florida
I have a kicker 2500.1 and I am going to be purchasing two dual 1.4 ohm subwoofers. I know my amp isnt stable at 1 ohm and only 2 ohm stable but my question is,will I be able to run the subs at 1.4 ohm since imp. rise might bring them up to 2 ohm or somewhere around there or will I not be able to run them? thanks.
Well I have enough of an electrical to keep the volts up where they need to be,and at lights i turn it down until i am driving again just so there is no real strain on anything.
As long as you've got the electrical, you'll be fine. I've heard of people running these amps at one ohm with no problems.
It also lowers the amps efficiency and raises the current draw.
694
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
494
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
eutechnyx
eutechnyx
florida
modskwod
