1 ohm stable amplifiers under $300??? Sundown, DC, Soundqubed, RE?
  • 3
I've been looking for a month or two at brands such as sundown, dc audio, soundqubed, re audio, etc, and all I keep finding is conflicting reviews on what or who is the best. I have an alpine swr-12d2, and all I want to do is find an amplifier that it will work well with at 1 ohm, for under $300. I've heard you can also get an amplifier that has a higher rms rating than the sub, but just keep the gain turned down, so I was looking into that as a possible too just incase I would decide to add another sub or upgrade the sub at a later date. Also, the alternator in the car is the stock 105-110 amp in a Buick, but there's a yellow top optima battery under the hood. So running at 1 ohm, would I have to do any other upgrades such as the big 3 or not? Any help would be appreciated, thanks
big 3 and you should be fine. all those are great companies pick whatever fits your budget and you like. as for getting a powerful amp and getting another sub down the future you kinda wont be able to unless you get a HO alternator and upgrade to 1/0 wiring and second batt. so if you want to keep stock electrical and be SAFE keep it around1k rms.
definately do the big 3 itsll help. make proper bolted down grounds, and set your gains correctly.
soundqubedd 1200, sundown has numerous 1k amps out there, dc has a 1200, theres also american bass, crescendo, therers plenty to choose from since you got a D2 sub.
Thanks for the quick replies guys. @C1500martin, those other brands you mentioned are all great brands too. Now, another question. I have 4 gauge ofc power and ground wires, would I need to upgrade them for one of these amps or is the 4awg ok? It has an 80 amp inline fuse, and the Sundown I was looking at (Sae-1000d) has 3 40 amp fuses in it, so that combo can't be good..
[quote name='Ace87']Thanks for the quick replies guys. @C1500martin, those other brands you mentioned are all great brands too. Now, another question. I have 4 gauge ofc power and ground wires, would I need to upgrade them for one of these amps or is the 4awg ok? It has an 80 amp inline fuse, and the Sundown I was looking at (Sae-1000d) has 3 40 amp fuses in it, so that combo can't be good..[/QUOTE]
you fuse for the wire not the amp, so if it REALLY is 4 gauge ofc get a bigger fuse 150A. 80A is for cca. i run both types the ofc in my car, cca in my truck and thats how i have it fused. i also run your power around 1k for my sub stages. 4 gauge is fine as long as it quality 4 gauge.
It also lowers the amps efficiency and raises the current draw.
5
467
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
303
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
998
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
Ace87
Ace87
NE Pennsylvania
C1500martin
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
