SOLD 10" Fi BL Dual 2 Ohm- FRESHLY RECONED
Joseph K
Arkansas
I am selling my 10" D2 Fi BL. I had it in an underseat ported box with around 900 watts going to it daily. I fried one of the tinsel leads about 3 months ago, and sent it off to Fi. They reconed it with the integrated leads, so that can't happen again. So pretty much, this is a brand new 10" BL, it's not really even broken in yet. I haven't really been playing it too much the last few months. I'm switching to two 12"s sealed.
I would rate it 10/10 on appearance and 10/10 on performance. These are awesome, BEEFY subs.
Specs:
DUAL 1 | DUAL 2
Fs: 37.1 Hz | 37.1 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 4.62 | 4.62
Qes: .23 | .23
Qts: .22 | .22
Mms: 191g | 191g
Cms: 0.96mm/N | 0.96mm/N
Sd: 310cm^2 | 310cm^2
Vas: 13.0 l | 13.0 l
Spl: 86.2dB 1W/1m | 86.2dB 1W/1m
Bl: 16.6 N/A | 22.7 N/A
Xmax: 18mm | 18mm
Rms: 1000W * | 1000W *
Sealed box: N/A cuft | N/A cuft
Ported box: .7-1.5cuft | .7-1.5cuft
Sub OD: 11.000” | 11.000”
Cut ID: 9.250” | 9.250”
Mounting depth: 6.250” | 6.250”
Displacement: 0.16cuft | 0.16cuft
https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154bbe1697830f5/shopdata/0050_Speakers/0020_BL/product_overview.shopscript
Asking $225 plus shipping. Not really sure on that price, so feel free to make offers. I don't know what these are going for slightly used... Will have pictures up later. I have lots of refs on this site as well if anyone needs them. Thanks!
Haha yes, just a little bit. **** it weighs more than my 15" Q did. It handled every bit of ~1300 RMS when I used to have the gains up all the way... Yet for some reason I'm having trouble selling it...
Define this for me. Gains up all the way?? Can we get a coil check?
Buy the sub and coil test it yourself //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I agree. I would like to see a coil test and pics posted of the coil test. Nobody want's to buy a sub with a burnt coil. I am interested in this 10 though. Is this thing capable of handling around 1800 daily?
If the sub is damaged or abused, the buyer has a right to know.
Coil burnt? The sub is fine, it has been exactly as it has been since day 1 that I've had it... Get out of the thread if you aren't interested in buying this, please.
Idk 1800 might be pushing it seeing as this one has none of the cooling options or anything... I know people have ran them with around 1500 with no cooling options, but honestly I'm not sure.
I'm absolutely interested, but when you publicly claim to have done something that probably damaged the speaker then claim it is perfect, I question which is true. Buy a DMM and post pictures of the readings and post the best pic you can get of the coil and you can prove your statement. This is absolutely not dumping. Just some clarification for the purchaser.
I didn't damage the sub, it's been babied very much so... I believe my dad has one, I'll get a coil test for you. Not sure what setting I need to have it on though?
474
661
986
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
928
Joseph K
Joseph K
Arkansas
Jaredturp
