1000 or 1200w Amp options
  • 3
Sc0rpi043
I am currently running 2 10w7s off an HD 900/5 and its just not doing the justice at all not to mention I have Hertz HSK XLs in the front that are bright as ish. I am looking to lose the 500 on the HD 900/5 amp and just buy a separate 1000 or 1200W amp to power these subs in a sealed box. I need some modern day recommendations for an amp that may not be as expensive as a JL HD 750/1 or 1200/1 series but does not sacrifice SQL
Thanks in advance!
PPI P1000.1 is rated for 1,000W @ 1 Ohm and it's underrated by about 20%. At 14.4V you should be peaking around 1,000W RMS on test tones. It's not a regulated design like the JL HD amps, but I think you would like it. If you want to spend more than ~$200 let me know.
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
804
Sc0rpi043
Sc0rpi043
Northern Virginia
trumpet
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
