New setup, one problem
  • 2
nft987
I recently installed Focal 165 a1 component speakers. The tweeters sound great but the woofers sound very thin and tinny with almost no low end almost like big tweeters. They are hooked up to a Sony DSX -s300BTX head unit and Pioneer MD6500f amp. I also use a JL audio 10w1v2 subwoofer connected to a JL audio amp that fills in most of the midrange. But I know the system would sound better if the woofers would do their job and fill in the rest of the middle of the sound like they are supposed to. When I listen to the system without the subwoofer it sounds very empty and bright. The amp produces the power required by the specs of the Focal speakers.
My question is just, what can I do to get the woofers to do their job and give out some low and midrange? I'd like to hear any ideas anyone may have. I have tried everything possible with every EQ I have in my system and I set the crossovers to favor the woofers. I'm out of ideas.
Thanks very much!!!
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
600
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
7
922
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
nft987
nft987
New York, NY
mylows10
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
