1000 watts
patton422
Guys I have been out of this for a long time I just picked up some subs for cheap. I only need 300 watts but I want to wire it up and get a amp to handle a whole lot more for my next sub. so what should I look at for around 800-1000 watts rms and not really expensive
I knew so many people running the HiFonics Brutus amps years ago because they were a solid source of low-cost power, and the YouTube shows a bunch of people with 'em now with mostly good results.
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
777
patton422
patton422
New Jersey
Symon_say
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
