Fusing amps question
  • 1
waccord99
Jersey
alright i have 2 amps one has a 40 amp fuse on it....the other had a 80 amp fuse on it......i have upgraded it to a amp with a 120 amp fuse on it......on my distribution block i always had a fuse before the amps and now i cannot find a agu or anl fuse anywhere locally that is 120 amps......my friend has been running both of his amps without fuses on the distribution block...he told me it doesnt matter......does it??.....i currently have a 150 amp anl fuse up front by the way
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
439
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
566
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
waccord99
waccord99
Jersey
waccord99
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
