12’’ FI Q Dual 1
cman0655555
12’’ FI Q Dual 1
Q12 - Fi Car Audio Store
Dual 1 ohm
Cast basket
Wrap around gasket
Kraft pulp fiber reinforced cone
Single layer wide foam surround
Push terminals
Extra heavy lead wire
FEA optimized motor
3" diameter 4 layer coil
Single high grade magnet
Quad progressive spiders
High or low Qts motors
Optional Heli-cool system
And many other custom options
Q12
DUAL 1
Fs: 34.2 Hz | 33.9 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 7.63 | 7.69
Qes: .39 | .39
Qts: .37 | .37
Mms: 249g | 253g
Cms: 0.87mm/N | 0.87mm/N
Sd: 481cm^2 | 481cm^2
Vas: 28.3 l | 28.3 l
Spl: 86.5dB 1W/1m | 86.3dB 1W/1m
Bl: 13.9 N/A | 19.65 N/A
Xmax: 28mm
Rms: 1500W
Sealed box: .8-1.5 High QTScuft
Ported box: 1.8-2.5 cuft @ 28-33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 7.000”
Displacement: 0.16cuft
NO TRADES! $200 shipped anywhere in the continental US. If you’re local we can meet up or I will drive to you for a small fee.
Fresh Recone. Great condition 8/10 cosmetic 10/10 function. Great sub planned on using myself but never did. Sitting around so it needs to go. Has 2 very small scuffs on the surround and typical scratches on the motor.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
512
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
686
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
994
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
933
cman0655555
cman0655555
Carlisle, KY
Phish
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
