'12 Mazda 3, Stereo cuts out. Dealership told me my amp draws too much power? 800w
  • 1
viwil
Currently installed/Install date
August 2016:
Kicker 40KX800.5
JL Audio C2-570x (Rear)
Focal 165 AS (Front)
Rockford Fosgate Punch P1 Subs x2
November 2016:
Pioneer AVH-4300
The stereo runs great until I let off the gas (while in gear) then the system cuts out (amp/sound) deck/lights remain on. After clutching or touching the throttle the system comes back. Isolated the cutting out to the Amp shutting itself down due to a voltage spike 15-19v. This spike only happens in the cold
Issues accorded Prior to deck install, original thought was the stock deck was going out.
I am told the stock Alternator should not have an issue with a 800w amp.
I get a voltage range of 11-19v, but idles steady 13.6-13.9v despite engine RPM (tested 600-4500)
Things I have done:
December 15th 2016 I replaced the battery
March 9th 2017 I took the car to the dealership to get tested. (came back as Amp is drawing too much power)
Taken it in to the Stereo shop to check the installation
Kicker 46CSS654 CS Series 6-1/2" component speaker system chose these for the front chanel Kicker 46CSC654 CS Series 6-1/2" 2-way car speakers...
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
189
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
671
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
6
577
viwil
viwil
Montana
viwil
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
