Bose amp wiring harness for 2014 mazda cx5
  • 2
ziggy@2022
CarAudio.com Newbie
16
usa
Hello, I was wondering if anyone could help me out ? my issue is I have a 2014 mazda CX5 grand touring edition thats came with the bose amp package I believe the amp is bad and I would like to bye pass the amp and add a four chanell aftermarket I just don't know what wires to tape into ? if I wanted to replace the factory radio as well and add a amp and also replace the front speakers with a set of components . if that is the case where do i tape into the speaker wires is it behind the factory radio or is it at factory amp location and if that's the case which harness has my speaker wires ? I am adding an image is it the green harness or the black one ?
44751
Make sure your speakers are 2 ohms or higher or you'll have problems with the aftermarket amp. Do you know if your speakers are actively or passively crossed over? Might want to check a Mazda forum for more insight.
I know the car came with two ohm speakers in all the doors I am replacing them with a set of aftermarkets components up front and a set of coaxials in the rear , they are 4 0hm . the mazda forums have not been much help , I think the front has a set of factory components meaning the tweeters in the dash provide the highs and the lower door speaker is meant as a mid bass
Kicker 46CSS654
CS Series 6-1/2" component speaker system
chose these for the front chanel
Kicker 46CSC654
CS Series 6-1/2" 2-way car speakers
rear speakers
Soundstream Reserve RSM4.1200D
Compact 4-channel car amplifier — 75 watts RMS x 4
well ****, thanks anyways. Will leave the thread open just in case someone knows anything :)
@1aespinoza I see, so this audio volume leveling is what I was experiencing tapping into the Bose sub wires. Well then, I'm off to check out the...
4
The harnesses showing up for your vehicle show one or two adapter plugs. If your car has a separate CD player, then I assume that is what the 3rd...
Yeah, I really enjoy this site's members. There is so much combined knowledge and camaraderie that it is difficult to stay away. Yes, alot of us...
5
842
ziggy@2022
CarAudio.com Newbie
ziggy@2022
usa
ziggy@2022
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
