xshlomox
Hey guys, I've been researching and I think I am about to purchase a 12" Fi Q because of all the good reviews. I just have a couple questions regarding the sub itself. On the website, it can come with a bunch of options and I don't know what they are. Can someone explain dual 1 vs. dual 2, spider, P chamfer, I heat ring, high QTS, and cooling? What amp would function well with the sub? Also, does the Q sound better in a ported or sealed box?
Thanks so much!
do you plan on running it sealed or ported? you can get the high QTS and heat ring to make it better for sealed, or if you dont it performs well in ported. IMO i would run it ported if you can since they have the ability to dig low
Thanks for the recommendation, and yes, even though I've never built a box before, I'm gonna attempt to. As long as I have all the right measurements, it shouldn't be that hard but I could be very wrong.
Also, thanks for the discount code.
its not very hard TBH. RAM_Designs or buck can both make you some very good setups for getting the most out of your Q. sheet of MDF costs $30, comes in 4x8. glue and screws cost like $10 lol.
Okay, but usually people don't know what sound quality is. It isn't what it generally means. The SSD sounds great too. But nonetheless, if you want the Q, its a great sub. I'm building a box for it soon.
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
366
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Thanks for the reply bass addict. I am sure with ya'lls help I'll get it tuned up. Audiobaun has been a huge help. He basically linked everything...
50
5K
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
8
xshlomox
xshlomox
Long Grove, IL
Fi Car Audio
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
