15" fiberglass enclosure, fits 4th gen (90-93) Honda Accord
  • 2
objext
This is a custom fiberglass subwoofer enclosure, molded to the contours of a 4th gen (1990-1993) Honda Accord trunk, driver side. It was built for a 4dr sedan and held an Adire Audio Brahma 15" sub. I built the enclosure myself with hand-laid fiberglass mat & cloth with polyester resin, then smoothed and painted. Awesome, bomb proof enclosure, but my Accord is getting worn out, and I also have a new baby so I need the space, not the bass. The pictures are from the original install which was used up until a few months ago - it has some wear & tear, but would only require a little filler/sand/paint to look like new. It bolts through the inside to trunk frame rail, and has pass through brass bolts for wire hook up. As measured with styrofoam packing peanuts, it came out to 2.5 cubic feet, which was matching adire's recommendation for a SQ size for the brahma 15.
$200 obo, + shipping if applicable. I really need this gone, so feel free to make offers.
Gallery of build pictures:
http://www.objext.com/fgbox/
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
792
objext
objext
Santa Barbara, CA
objext
    Jun 1, 2024
    May 31, 2024
