Boat speakers- treating existing fiberglass to improve the "box"
chazzy
CarAudio.com Newbie
11
Florida
I'm replacing the speakers in an old sailboat with a pair of Rockford RM1562. They're mounted under the seat and are essentially infinite baffle... the seat is open to the cabin below. I'm only wanting to stiffen/deaden the fairly flat, 1/8-1/4" thick fiberglass panes that they're mounted in. The current plan is to just surround the speakers (1' radius or so) with dynamat. Any other tips?
Id look at some ABS
Rethinking it, dynamat cars are space restrictive. I have basically no restrictios behind the wall. Could roughen up the fiberglass and glue something dense to it. Thick piece of abs/acrylic/some plastic sounds good. cementitious construction material like hardie board or something bathroom related?
Maybe Concrete Board also?( May last quite a while also?) if you are Inclined to work with it with a Diamond blade and Small grinder to make your cuts?Or Skill Saw? May be worth the effort? ABS is pretty Cheap
We used to turn our Skil (one L) saw blade backwards when cutting Hardy, cement board, stucco, and even corrugated metal.
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements off of it. Anything to add mass and rigidity would help.
That said, is the boat body so thin that a 6.5" speaker is really vibrating it and even needs reinforcing?
How easy is it to get up behind where the speaker mounts? Could you find some sort of 6" pipe to mount back there to act as a "box"? I'm thinking 6" PVC pipe end cap or something.
Can you post pics?
Lowering the impedance will also lower the speakers motor control, or damping, in physics no free lunch exists. It’s all give and take.
4
194
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
383
It may be that they act like this because they are underpowered and the push to play them louder is causing the amp to clip the signal, which will...
what ^ said. amp gain setting info, test tones are at the very bottom...
257
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
chazzy
CarAudio.com Newbie
chazzy
Florida
hispls
winkychevelle
    Apr 27, 2024
audiobaun
    Apr 27, 2024
Latest topics
