15 Re MX enclosure question
  • 2
lilbone44
i just picked up 2 re mx 15 that I'm wanting to replace my 2 ssi Treo 10 going in a 98 Mitsubishi eclipse hatchback. i don't want to do a wall but open to that opinion if nothing else. i check on re website and they had very limited info on these and wanted to know if 7.3 cu ft (before displacement of subs and port) is a good size to run them on a audiopipe 3000.1. Box would be around 34L x 22W x 17H max ported. Sub face inward, port firing up. this is with some fiberglass work to the face of the enclosure. Wanting Any helpful opinion.
This is my thought as well. Would be a much better box volume if you could buy the 12" version of those subs.
1.25 NET cubes. You have to add the sub and port displacement to the box. I'm guessing that you will be around 1.7 net before sub and port...
7
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
lilbone44
lilbone44
Gainesville' fl
Buck
