First sub build question.
  • 1
therealjroc
Ok. So I want to build a custom sub box for my Colorado Extended Cab. This is my first box so few questions.
1. I want to build a box to the sub specs then have a large face inside. Is there anything special I need to do or as long as the inner box is solid the rest will be fine?
2. I'm thinking about rounding the edges, filling the gaps, and covering it in black plastidip to my the plastidipped accessories in my car. Is there any issue with plastidipping instead of carpet?
I'll post pictures of the space it's going into. (replacing Infinity basslink) and a sketch or two of what i'm thinking about. Not sure If I want to surface mount the amps or hide flush mount. Again, this is my first build, so if you see anything that might be an issue let me know! Thanks!
View attachment 26540348View attachment 26540349View attachment 26540350
Alright man .that is what i have been leaning torwards .i appreciatte your opinion . I feel like the 18s will be great for a daily without having...
7
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
126
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
282
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
461
therealjroc
therealjroc
Clarkston, GA
therealjroc
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
