1970 chevelle suggestions
  • 2
sqhertz
Miami ,Fl
need some suggestions for front speakers for a 70 chevelle ss. theyre 4x6 and apparently the driver side cluster is right behind it. found this pic from a place that does oem replacemtns (8-10 ohm only) that shows what the back look like
Original Delco 4x6 dash speakers for Chevelle shown on top. Notice the difference in the magnet size and location between the left and right speakers for instrument panel clearance. If you look close, you will also notice the angle brackets are in different positions on the driver side verses the passenger side speaker.
The middle picture is our 4x6 speakers bolted to the dash speaker support brackets. (Stamped dash support brackets not included with our speakers.)
The bottom picture shows our 4x6 speakers with the angle brackets. Our speakers with the angle brackets installed for Chevelle/Monte Carlo sell for $79.95 a pair.
looked at kick panels and they ones ive found have issues with clearing the pedal and having some made is out of the budget.
can anyone suggest another option?
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
859
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
4
634
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
You might get some inspiration from the install that I did... Delta Audio Install
11
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
857
sqhertz
sqhertz
Miami ,Fl
Jes 42
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
