1990 b2
An Excide AGM battery might be within your budget??
Thats what this leadacid is 75ah excide Titan, maybe I bout a bad one? Resting voltage was only at 12v?
Sent from my 5054N using Tapatalk
Think it was a bad ground, ran one of my 0gauge to the frame (I guess technically I had 2 on the engine, one on block and one on alt mount, redid my 4guage body ground and looks like voltage drop is gone atleast till amp starts clipping also cleaned up the wiring a little
Still. If it was an amp ground. Id never put it there but as its a big 3 ground. No biggie.
Sent from my SGH-T999 using Tapatalk
Yeah it's big 3, once I have the inner fender well on it's actually covered, I have it taken off right now cause I gotta replace the exhaust manifold
I'm running a single hds208 on a sounqubed 2200 @.5 with an xs d3100, big 3, and it has been handling the power like a champ. Don't know how you slinkied your coil so easily. I just have to be careful not to bottom out the sub.
I'll take a video if anyone is interested.
I was clipping it real bad didn't have gains set plus it was wired to one ohm when amps only rated at two
Makes sense. I probably have crazy rise too. The most I've seen ran to one is 1700w clamped. He ran it well into it bottomed out and the former bent. Coil was still shiny lol
Oh yeah mine bottomed out hard anything less than 35hz which is what box was tuned to
0 gauge should be here tomorrow trying to decide if I should sell what I don't use ore keep it for when I have money to start my battery bank
dev199505
dev199505
US
dev199505
