1996 Ford F150......sub stage possibilities?
  • 1
Ridinhi
Father recently passed and I now have his f150. As far as I can tell,I'm keeping it as long as I can before passing it on to the next person in the family. Anyways, it will be a daily driver and sometime in near future I want to install a budget system. Prob is, the truck is a standard cab. Pretty much no room behind the seat. Thinking about maybe four Massive Audio summo 6.5" subs ported Or maybe just two of them in a t-line if that is possible. If anyone has any experience with a truck such as this one please give me your opinion on the possibilities on a sub stage.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
905
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
3K
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
Ridinhi
Ridinhi
Winston-Salem, NC
Ridinhi
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
