Subs losing power
  • 3
Jacobgat4
Ok so i have a 15" 3600W pyle subwoofer hooked up to a 1000W amp. I just put this in a few days ago and ive noticed that when i first turn my music on, the sub hits but it definitely doesnt hit like it should. The second thing ive noticed is that after playing my music for about 15 minutes the bass barely even hits at all. It seems like it just starts losing power after i start playing music and this happens every time. Anyone know what my problems could be or have any suggestions? Anything would be appreciated.
Thanks
1. Check the wiring of the subs. Make sure the connections are solid.
2.Have you tried adjusting your amplifier? Try increasing your gain.
3.Is your low pass filter on the correct setting?
4. Lastly, try using another amplifier to see if its your sub or the amplifier. The amplifier may be bad.
Good luck.
Read the instruction that cam with your amplifier. Is it capable of driving your sub.
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
105
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
419
If they had an orange basket I would have to buy them.... Hmmmm Sell my 4 Xs and get 6 of those and do no-wall again with one more 4500..... :unsure:
4
561
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
826
Jacobgat4
Jacobgat4
St louis
Umphism
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
