1997 Jeep Cherokee Sport
Bologna
Ad ministrator
590
USA
I have a 1997 Jeep Cherokee Sport SE, 4 door, 4.0L v6
It won't start, it'll turn over but that's it. I just bought a brand new battery and it still won't work so that's not the problem.
It worked fine the day before but I went to turn it on in the morning and it wouldn't start. And my Jeep is kept in my heated garage every night too so it wasn't the weather.
I can start to smell gas when trying to turn it on especially when I open the hood. Not sure what that means those.
Any help is appreciated, thanks.
lol, its ok
The coil is what sends spark to your spark plugs. They can and do randomly die. Pretty easy to replace.
There is a pickup of some sort in the distributer that can go bad...should be easy to replace also.
These would be where i would start if it was me
lol, its ok
Alright, I'll check that out tomorrow. I'm making a list of possible problems. Other things I have written down to check is: Fuel, air filter, compression, spark plugs, and crankshaft position sensor.
crankshaft sensor is the only one out of there that would make it just stop running one day. Maybe, and just MAYBE the fuel filter.
The spark plugs were getting spark but I don't think enough. They sparked like every 1.5 seconds when i was cracking it over. I think it should spark faster than that.
I just towed it up to the local car mechanic and I'm going to see what he says. But he said it'd probably be Monday before he looks at it.
That spit sputter spark you see when you are cranking it over is going to be some what normal. Your not going to get a good spark(well constant) from it because its not up and running. What kind of spark tester were you using. Also were did you test it.
Pulling that cap off and check the cap and rotor you could of done yourself very very easy to do on a jeep 4.0 motor.
My next thing is you say you can smell fuel under the hood. Its fuel injected you shouldnt smell fuel at all under the hood unless you have a leak some place. Could very well cause a no start.
When you were sitting in your jeep cranking it. Did you happen to look at the RPM gauge did it go up from zero when you were trying to crank it. Or did it just stay at zero the whole time you were cranking it.
All I did to test the spark was take off the cover for spark plug # 6, I believe, and stick a screwdriver in there and laid it across something that was grounded.
I believe the RPMs sat at 0. Can remember that well.
Hmm...makes me wana say its the lil magnetic pickup in the distributer. I forget what theyre called on the jeeps...
and could you here the fuel pump turn on? its uncommon for them to just die. But it is possible
Its a cap and rotor type. What you and others are thinking of is a tad bit older in age, years. This type the rotor sits on a shaft and spins around sending spark to each spark plug through the cap from the coil.
Now saying you think you seen the RPMs just sit at zero while you were cranking it. Says crank signal. Crank position sensor do go bad on the jeeps all the time. And will give you a weak spark while cranking. That sensor sits on top on the bell housing area. Near the steering shaft.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
425
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
6
823
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
8K
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
12
Is anyone familiar with, or can help with the Infinity system (with amp) fitted in 2001 Jeep Grand Cherokee? I've installed a Atoto A6 head unit...
Bologna
Ad ministrator
Bologna
USA
audioatg
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
