2/3/4 channel amp with dual vc subwoofer 2 ohms each
  • 1
qguy
What is the best way to connect sub to amp ?
Option A
1. Set amp as 2 channel
2. Connect the sub in series and connect the sub to one channel of the amplifier (note that the amp is not mono and configured as 2 channel mode)
Option B
2. Connect 1 VC to left Channel and other VC to right Channel
Amp specs (2/3/4) channel
Power Specifications - Full Range Channels
RMS Power @ 4 ohms 65 watts x 4 channels
RMS Power @ 2 ohms 75 watts x 4 channels
RMS Power @ 1 ohm Not Stable
Bridged RMS Power 150 watts x 2 channels
Subwoofer specs Dual VC 2 ohms each, 300 watts
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
315
6
453
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
838
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
877
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
qguy
qguy
Philippines
qguy
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
