2 Alpine Type R 15 Getting hot
  • 4
Chov1ch
19
Rijeka
So.. I had one Alpine type R 15 (4 ohm dvc) in 4cuft box(32hz tune) on Hifonics brutus bxi6000d (2kw on 2ohm) with 0 gauge wire, 75a alt, 2x 55ah batteries and it was working like a charm.. subwoofer was moving 15-20mm in one way no smell and he was cool.. and now I put another Type R 15 so two alpines wired to 1 ohm (3kw on 1ohm) and subwoofers are not moving even 8mm in one way but getting hot.. do you know where could be problem? My lights are not dimming so I think electrical is good enoguh. what you think?
Sounds like you're out of power overdriving the amp and overheating the voicecoils. Have you measured voltage at the amp when you're driving it hard? Have a beefy ground?
-Eric
Sent from my SM-G930R4 using Tapatalk
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
559
On a sealed sub box if I faced the subs up, I lost quite a bit of bass. Faced them forward, they worked great. On a ported box with subs and...
I would just go with a ported box tuned from 32 hz. - 35 hz.
Chov1ch
Chov1ch
Rijeka
llebcire
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
