2 amps????
  • 3
TheDem6n
I'm not sure how to go about this:confused: ! Currently i have a Pioneer P80MP, sub and a American Pro amp (2chanel 600w max) and all works very well, i just bought a set of pioneer components for the front and pioneer 2 way for the back and a gbl 75.4 (4chanel) amp! How do i go about connecting a second amp???? Got an 8gauge power cable at the moment, was gonna get a power cap but there is a myth that they dont work so what shoul i do //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif ?
New power cable? Distribution blocks fused not fused have no idea:confused: !
So please help!
p.s havent got allot of money to spend and want the easiest solution possible!
4awg cable feeding from the battery (fused near the battery so you'll want a fuseholder for 4awg cable as well) going into a distro block that accepts a 4awg input and has either 4awg or 8awg outputs.
From the output side of the distro block you'll route power cable to your two amps.
Easy as pie //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
what are the ratings on the amp best bet is to uprade ur power wire to a fused distro block to ur amps. one main ground to a good ground location to a gorund distro. block and to ur amps.
the current power cable is fused near the battery, so same thing again with a 4awg cable and fused block for power cable and non fused for the earth! is that rite guys?
Correct. //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
There is no need for fusing on the ground (earth) connection(s).
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
429
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
558
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
TheDem6n
TheDem6n
Cambridge, Uk
TheDem6n
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
