2 different amps
  • 3
mirracomitch
ok so i had a rockford fosgate 400.4 amp and a audiobaun 10" sub in my single cab silverado. i got rid of the sub and i am replacing it with 2 punch p3 12's.i also bought a crunch 1400 watt 4 channel amp. i want to use my fosgate amp to run my speakers and use the new crunch amp to run the subs. im trying to find out if this would work.
thanks in advance!
mitch
As long as you don't overpower them, there is no danger of harming your gear, once you get a new sub so they are both the same, you will likely...
12
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
8
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
mirracomitch
mirracomitch
bakersfield ca
mirracomitch
