Hello, i have questions from low notes in my car...
My system info and my problem: https://www.caraudio.com/threads/ba...imes-bass-subwoofer-problem-bass-loss.613260/
Issue: Sounds like crap. Bass is not loud, no soft or weird.
1. This issue, not great sound, can be caused by Electromagnetic interfence? (Problem is going on two amps,)
2. Is there a possibility, that there are any properties in the quality of the current?
3. Is bad grounding, causing no voltage drops or small? I dont see difference with voltage drops, if system play good or bad, voltage drops this same, Could there just be a meager difference, which can affect the sound though?
(My amp grounds from battery and head unit, but, after silent listening, amp, and head unit is warm, normally?)
3. 2. Are amps and HU ground from battery (IN TRUNK) its not good connection? My Ground wire from amps is more longer than power wire (power wire about 80cm, ground about 1,5meter per wire) Its can be problem?
4. what else can affect my low notes sound? Bass is not clean and loud, no soft. Sometimes bass can play better much... I checked all connections, grounds, fuses, its look good... all audio system is fine, there is nothing defective.
5. How did you fix your weak bass issues?
Thanks.
Thanks.
