2 ground and power wire terminals?
Yes, you MUST run both pairs.
Although, if you're asking this, I doubt your electrical will be able to support this amp.
What does your electrical consist of?
U don't have to. Lol the amp will still function with just one hooked up... But I wouldn't recommend it. Hook both up
Right, they're just connected in parallel by bars on the inside of the amp.
It will function for testing, but I wouldn't run it that way permanently... //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Shammyhavik did that, blew his amp because of low voltage, then blamed the guy on the forum who sold him the amp.
Oh my gosh I remember shammy
Anybody asking questions about a high power amp shouldn't have one. Esp asking about dual inputs.
I would highlt suggest studying it to find out proper install and about a good electrical before hooking it up.
Well that was nice encouraging post. Not everybody is an electrical engineer.
You don't need to be an electrical engineer to hook up a dual input amp. What if it was 3?! He'd be really lost.
Like how he says he knows a lot about car audio but questions this. lol
I do know a lot about it, like I said I've never dealt with this much power, I apologize for not knowing how to wire up something I've never had experience with
Look man, it's not any different if it had a single inputs, like a lot of amps do. Instead you have one that has 2. Just as simple as an amp with one. Ground both negs and put an inline fuse holder/fuse in between pos leads/power wires and your done.
  • Locked
Thanks for the quick rep and it was great chatting w/ you. Good luck w/ what we discussed. It rare but sometimes I stumble across odd and ends...
18
3K
I have a 2012 Ford F150 Platinum Crew Cab. I was saying that since my secondary battery would be grounded to the frame could I not ground my amps...
4
Carsonb99
Carsonb99
Greenville Mississippi
adulbrich
