Do you all do anything for power/ground wire ends?
I have my power and ground cables mounted pretty taut, there's really no slack. I don't want to pull the power and ground cables out of their mounting screws because then you fray a wire, and may lose a strand or two each time. Might be harder to get back in. I just don't want to pull em out and keep tightening the set screw on em. What other options are there? I know at one point, I tightened a wire with a zip tie and soldered it just enough at the tip.
Could I just use a gauge reducer? Is there some other way so that if I pull it a few times, I don't need to either cut it clean to have a good connection?
Always terminate my ends, if not lugs they go in input adapters. I also have my power and grounds running from dual amp inputs to a 2/0(350A) connector (commonly fork lift battery connector) to lugs connected to power and ground distribution. I just got some of those new set screw lugs from ill to try out. I like having the ability to take it off and the wire be used elsewhere and if a lug end is not needed. I also use adhesive lined heat shrink and all wires I try to have plenty of slack and/or secured in a way that if anything tugs on it the pressure is not on the end(P clamps, insulated clamps, AN clamps or zip ties)
That's all in installs I do though. My s..t is crude as f..k! 😂🤣😂🤣 besides the forklift connectors, that's only in mine.
Thanks everyone for the replies! Like I said in my first post I’m not wanting to be loud, I just would like to have a little extra bass.. I like...
12
790
Ive been looking at amarican bass xd 1222 or 1244 ,and sundowns e series, they both seem very good , can't verify sound quality tho but I know...
37
9K
I am building and selling the subs. Like to get input on if basket colors options would be a winner. I do custom painting on guns already.
998
HardofWhoring
Phoenix, AZ
Jimi77
winkychevelle
    Apr 27, 2024
audiobaun
    Apr 27, 2024
Latest topics
